Just wondering if I have to go high dollar or can cheap out on one for my stroker 351w. Whats best, steel, aluminum? Anyone have problems with a cheap one? Lets talk about this
Hey thanks man. Drop me a PM when you want to try and I'll help you through the process...PBbentley429 said:I would like some info on this as well. Paul I just took a look at your car domain, very nice car. I was impressed by your polishing skills, i think i would like to try someday.![]()
I got the strongest one I could afford.04sleeper said:All main girdles do basically the same thing, hold the peices together when the engine blows up.
I have never had any hardcore engine builder tell me that they help.
They say just buy a stronger block.
PM Rick91GT and ask him. He can answer your question.pb_paulie_b said:I got the strongest one I could afford.
Ok which one holds the pieces together the best?
Just a thought......dip your block in kevlar right before the cement.pb_paulie_b said:I just spent a fair amount of time doing a search (duh) and my final answer is to buy a canton main support so no machining has to be done to weaken the caps. I will bolt it on before block machining. This won't hurt block strength and will help a lil'. I 'may' also buy the lifter valley girdle. All told if anything $400 is to be able to re-use as many engine components as possible should failure occur.
I will also encase the entire motor in a block of cement and a gigantic vise to hold the cement together. Anyone still reading this???
