Roush Are my front tires rubbing under full turn?
sy1172
175
If I turn my wheels 90+% of the way it sounds like something is rubbing in the front. Are the stock 04 Saleen wheels technically too wide? I have the stock tires too!
It's not causing a problem, just a bit annoying.
Thanks,
Saleen adjusts the bump stops for the rack at the factory so the wheels wont grind the inside edge of the rim on the swaybay. It also cures the tire rub. It's an easy adjustment. The only bummer is you lose a little turning radius but you wont notice.
