  • 1994 - 1995 Specific Tech
are new headers suppose to smoke????
  • Thread starter Thread starter MI95Cobra
  • Start date Start date Feb 27, 2007
MI95Cobra
451
Oklahoma City
Feb 27, 2007
  • Feb 27, 2007
ok...finnally got the car back together:SNSign: ....i jb welded my old valve cover which i destroyed trying to get the old one off so i could put my new ones on(didn't know they wouldn't fit )....i filled the radiator while it was still jacked up and it looked like i had a leak (slow drip from the water pump?)....so i lowered it and the drip slowed down....i was like ok...let me take it down the street....about 1/2 block away i smelled something weird....i then turned around and went home when i got home...i saw a little smoke coming from the driver side headers(?) and i could hear a little exhaust leak from the passenger side....good news i then looked under the car and didn't see a leak.... so anyway i think i have the exhaust leak fixed...i think it was my egr tube......will know tomorrow....
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 27, 2007
  • Feb 27, 2007
If they're the high temp painted ones, they'll smoke for a day or two as the paint kind of burns-in (and eventually flakes off). I think the aluminized ones do that, too, since it's essentially a paint on them.
JJ95GTID
1,141
Phoenix, AZ
Feb 27, 2007
  • Feb 27, 2007
If you touched them at all with your hands or if anything gets on them it will burn it off eventually. I know when I work on the car I usually end up touching or grabbing the header with my dirty mechanix gloves. Even when I wipe off everything something still smokes off the header tubes for awhile.
M
MustangGT95
407
  • Feb 27, 2007
They usually have a coating on the inside to keep rust out of them. Usually smokes some and smells like ass.
I know my off-road H smelled terrible for the first day or so.
MI95Cobra
451
Oklahoma City
Feb 27, 2007
  • Feb 27, 2007
ok...i forgot to say that they are hts coated....also i used the metal gaskets that i recieved with my headers......i'm run them tomorrow after i get off work.....i'm not going to take a chance driving it to work yet...
Black95GTS
1,644
Marlborough, MA
Feb 28, 2007
  • Feb 28, 2007
I did my headers (new) and X pipe (used) at the same time. Without a doubt they smoked after install, I was freaking out but after some searching I relaxed. A couple days later it went away.
Having your car smoking and smelling awful doesn't instill confidence though.
Adam
gcomfx.com
3,690
Republic, MO
Feb 28, 2007
  • Feb 28, 2007
Adam
You should have your funnel pop out, while topping off your AODE transmission with fluid. Now that'll make you worried. Tranny fluid on a hot header = instant and thick white smoke.
1slow95
1,797
ohio
Feb 28, 2007
  • Feb 28, 2007
The first time I fired up my 418 the whole car slowly filled with smoke. It scared the crap out of me! But, my dad said it was normal, and it did stop smoking after a few minutes.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Feb 28, 2007
  • Feb 28, 2007
My BBK O/R H-Pipe smoked like a mofo.
Pokageek
2,767
MA, USA
Feb 28, 2007
#10
  • Feb 28, 2007
  • #10
Yep. My cars smoked like crazy between anti-freeze and oil on everything. I was trying to be cleanly too and still got it all over everything.
droptopford 5 0
427
Mar 1, 2007
#11
  • Mar 1, 2007
  • #11
no big deal... my mac o/r h smoked n smelled. then later when i did my aode-t5 swap i installed all the exhaust with dirty hands and a bunch of never seize. when that started smoking i could have swore i was frying the wire harness or the new puter. that def freaked me out a bit too
sn-95matt5-0
170
#12
  • Mar 2, 2007
  • #12
this makes me feel a little better
i changed my valve cover gaskets and used som degreaser onthe covers to get some of the crud off you think it would be normal for some thin white smoke to still be coming out of the engine bay
sorry to hijack the thread
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
