Are our alt brackets the same from the Fox bodies?
brackets are very much different as are our timing covers. the only way you can use a fox bracket is to change the timing cover as well, you may even have to redo wiring and such to make it work. once that headache is over you would prolly have to redo the other side bracket as they prolly won't attach to the fox timing cover.
Where did it break? Have some one weld it back together. Easy fix. But it's alminum, so you will need to tell them that over the phone when you are calling machine shops.
Scott
