Are upper controls THAT important?
  • Thread starter Thread starter The Fox
  • Start date Start date May 24, 2005
The Fox
354
Port Elizabeth
May 24, 2005
  • May 24, 2005
I'm ordering a bunch of suspension goodies and was wondering if I should just get the LCAs instead of uppers and lowers. The uppers keep the rear from shifting forward correct?
Anthony
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 24, 2005
  • May 24, 2005
Yes they are. Not only do they controll wind up but lateral (side to side) motion as well. Do the axel bushings as well. At first I just did lowers, better but I didn't see the full effect until I got the uppers.
J
jerryD
1,061
Gladstone, MO
May 24, 2005
  • May 24, 2005
if you get adjustable uppers, then you will also be able to change pinion angle if needed.
The Fox
354
Port Elizabeth
May 24, 2005
  • May 24, 2005
sounds good, thanks!
FiveLtrRiceEatr
197
Michigan
May 24, 2005
  • May 24, 2005
I just installed my adjustable uppers and theres a world of difference. Definitely go with them if you can.
Yep, thats the reason I got adjustable uppers
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
May 24, 2005
  • May 24, 2005
How hard are they to install?
FiveLtrRiceEatr
197
Michigan
May 24, 2005
  • May 24, 2005
they are easy to install. You have to grease their bushings and just pop them in, then take it to a place to adjust the pinion angle unless you want to do it yourself, but you have to have this meter, I forget what it was called. DTS did mine for free because they built my rear end, I just put it back in with my new rear suspension
J
jerryD
1,061
Gladstone, MO
May 25, 2005
  • May 25, 2005
checking pinion angle is easy. it is just the angle of the driveshaft in relation to the pinion yoke. usuall around -2* is a good starting point.
J
jerry beach
2,671
Ocala,FL
May 25, 2005
  • May 25, 2005
They can be a pain to install, if you change the bushings as well. MM sells a bushing removal tool for $40. One can build their own if so inclined. Search it and you will find all kinds of methods for removing them.
FiveLtrRiceEatr
197
Michigan
May 25, 2005
#10
  • May 25, 2005
  • #10
On the uppers I got they already came with bushings and most do. Its easy if you dont have to change bushings. Thats a pain. But every UCA Ive seen comes with bushings.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
