Are upper controls THAT important?
Yes they are. Not only do they controll wind up but lateral (side to side) motion as well. Do the axel bushings as well. At first I just did lowers, better but I didn't see the full effect until I got the uppers.
I just installed my adjustable uppers and theres a world of difference. Definitely go with them if you can.
jerryD said:
if you get adjustable uppers, then you will also be able to change pinion angle if needed.
Yep, thats the reason I got adjustable uppers
cjman15 said:
How hard are they to install?
they are easy to install. You have to grease their bushings and just pop them in, then take it to a place to adjust the pinion angle unless you want to do it yourself, but you have to have this meter, I forget what it was called. DTS did mine for free because they built my rear end, I just put it back in with my new rear suspension
jerry beach said:
They can be a pain to install, if you change the bushings as well. MM sells a bushing removal tool for $40. One can build their own if so inclined. Search it and you will find all kinds of methods for removing them.
On the uppers I got they already came with bushings and most do. Its easy if you dont have to change bushings. Thats a pain. But every UCA Ive seen comes with bushings.
