Its a street/strip yes but the power slows down around 5000 rpm. Its pretty clear that the TW are for NA 302s not boosted 342s. The runners are soso on the intake side, but way inadequate on the exhaust. I'm stepping up to the Torker II intake, and getting TPC to build the carb for me to blowthrough specs so it doesnt lean out at the higher rpms. I'll dyno then and see where she stands but my money says that larger runners will net more power and push the band out farther.
Reading that boosted heads have larger runners shows me that it is necessary to remove all that extra air out of the chamber. AFR even offers a boosted head with larger exhaust runners. Right now I'm really interested in the TF hig ports since the runner is a smidge smaller than the Roushs with a 197 or something and the exhausts are larger than mine at like 87 I think. Plus the chambers are 64 not 61 so the compression goes down which is good. And they are aluminum not iron. They seem like the perfect choice for my combo. I dont think Im floating valves since its only at 4900, plus the springs are rated to 600 lift and I'm running 542. The xcam may be a little small but rated to 6500 for a 302 so it should pull to at least 5500 on my combo. Besides smaller duration,224/224, is good for boosted engines.
