ARP main studs hit oil pump! help
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
I got a set of ARP main studs and main support(girdle) for my 347 and the stud right at the oil pump hits the pump.(stud is to long.) Is there a cure . and why does this happen. I cant be the only one with this? ....can i cut it? :shrug: :shrug: :shrug: All the studs are the same length as well.
thanks
pic of the problem
I grinded mine down, also grinded the pump a little to, also had to grind the nut, I also seen some pics where they put a 12 point nut there, it looks smaller then the 6 point nuts. Or u can use the regular bolt with no problems.
I have a Canton girdle on my 418w and they actually tell you that you may need to grind on the pump to make it fit (if you use a high-volume pump).
I had to take metal off the area that Markus showed above, and I had to grind down the gussets on the side of the mounting arm. Also, I didn't install the ARP washer on that particular bolt.
Apparently, this is a common issue, as my friend had to grind down the top of his bolt to make a std-volume pump work with his canton girdle on his 306.
