Ok here goes.I bought my 95 GT in Oct with 48k on the clock.after a few days i started to have a problem with starting the car in the morning after sitting all night it usually wouldn't start on the first try then i would turn the key back and usually on the second try i would start right up!So the local stang shop here in LI NY figured it was either the FPR or fuel pump,first i relpaced the FPR but no change so we went on to install a new fuel pump!Great problem solved for about two months it always started right up and ran fine.Then one day after shuting the car off and running into the store for a few minutes it started right up and stalled right away sometimes it would do this a second time before i got it started but usually ran fine after that!Then it started in again with the hard starting in the morning but this time it would also happen whenever it felt like it even when the car was warm!So i broke down and brought it to ford and they said it was the IAC motor and replaced it and again it seemed to fix the problem but then 3 weeks after that it all started to happen again.This is really geting annoying now some days it will run fine but as of late it's happening more often!Even going through the gears sometimes but not often it will want to stall i have to pop the clutch to keep it going and it usually bucks a little!Oh by the way i know our fuel pumps are a little noisy but on some days mine is louder than usual and i can hear the sound change tone when i step on the brake pedal!A code was pulled by the Mustang shop i can't really recall what it was but it was something like a bad ground between the p something or other and they really didn't know either!Anyway this is where iam at very fustrated.I really don't know what my next step is,replace the distributor or have someone go over the fuel pump install in case it was done wrong!So far i have replaced the FPR twice first with the stock then with a Kirban ajustable,Fuel pump,IAC motor,ACT sensor,ECT sensor,MAF sensor,Balancer(damper)!Plz someone with some knowledge help me out i love my car but i can't have this problem to much longer it driving me insane!
