I am planning on adding a H/C/I combo to my car, and keeping my Zex dry 125HP nitrous kit. I don't know what H/C/I to go with but before I do that I was wondering if my engine's internals need upgrading. I am hoping for 11sec times.
Most of it is all in the tune of the car. If your lean, you are more likely to break internals that someone who is running a more conservative approach.
JMO but even when you go HCI I don't think you'll be making enough power to have to worry about breaking the stock block with a 125 shot.
I was at 460+rwhp for over 2 years and 30K+ miles, it held no problem. I didn't start breaking things till I was in the 500rwhp mark.
i think the consensus is that our production blocks will take about 500rwhp with a good tune...of course there will be some that take more, and some that take less...but most agree that 500rwhp is pushing it for sure...
It's all a guessing game. If anything was slightly off spec when the factory assembled the motor, it will lead to a disaster later down the road. Or it may just say "beh, I am le tired" and go kaboom.
Just keep the a/f ratio under 12.0 and stay out of the throttle/bottle on the street.
Scott
That also depends on your choice of power adder. Turbo and centrifugal chargers are "easier" on the block. The power isn't instantly there as with nitrous and roots/screw blowers. This slower application of the boost (with the turbos especially) allows for higher levels of power. There was an article about this in either 5.0 mag or MM&FF just recently.
Their are products like the NOS Progressive Controllers. here is what summit says about it
SummitRacing said:
NOS programmable nitrous controller can be programmed to control both the amount of nitrous that is flowed into the engine (0-100 percent) and the time desired to "ramp up" from first hit to full flow.These features enable racers to fine tune the power curve of an engine to best utilize prevailing conditions. It's very easy to use, and each function is set through simply turning a series of dials to the desired position.
My crank let loose at 457rwhp..after 2 years. But on my car (S-Trim) I had alot more stress on the crank than you would...plus I went through like 3 stock balancers..lol
But for a example of stock internals there you go. All my pistons/rods did just fine.
