  • 1994 - 1995 Specific Tech
ATF Fluid Level
  • Thread starter Thread starter 94_302
  • Start date Start date Aug 5, 2007
94_302
438
Miami
Aug 5, 2007
  • Aug 5, 2007
I just finished my tranny cooler install no leaks so I'm happy. Everything I read suggests you will need to install about a qt of ATF. So I started it and shifted it into neutral and it ran for about 3-4 minutes. B&M says let it run for a few minutes in neutral. I checked it and the fluid level was right between the cold and hot. Then I saw in the manual it says to go through each gear and let it engage. So I started it and let it engage in each gear then back to park for another 3-4 minutes. I check it again and now it is right in the middle of Hot.
I just had a tranny flush at the dealer yesterday to put in Mercon V. It seems that after I have installed the tranny fluid it does not need any added. I was going to take it for a quick spin around the block and check again but if it stays right in the middle of Hot that seems like it's fine correct?
Has anyone else installed a tranny cooler and not had to add extra fluid?
R
red95gtconvert
382
Ponca city, OK
Aug 5, 2007
  • Aug 5, 2007
My fluid level didn't change by any significant amount after I installed my trans cooler so I just left it alone.
HISSIN50
34
129
Aug 5, 2007
  • Aug 5, 2007
If it's a stacked plate cooler, you should have to let the fluid heat up (stacked plate coolers have integral temp regulation). I like to check the fluid when fully hot anyhow (it expands as it gets hotter).
Good luck.
94_302
438
Miami
Aug 5, 2007
  • Aug 5, 2007
Yeah it's a stacked plate. I went for a drive on the road got on the highway for a moment and came back. Fluid was at the T on Hot so it's good. Next for the real test, a 6-7 hour drive tom. It probably needs to get some highway driving done anyways since it has sat in a garage for most of this year.
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
D
Brand New C6 Transmission Pouring fluid
  • Danielperry2003
  • Jun 17, 2025
  • Other Auto Tech
Other Auto Tech Jun 17, 2025
General karthief
