  • 1994 - 1995 Specific Tech
ATF out tailshaft?
  • Thread starter Thread starter Adam95GT
  • Start date Start date Sep 12, 2010
Adam95GT
2,564
Burlington, NJ
Sep 12, 2010
  • Sep 12, 2010
When we pulled the DS out to fix the flange i lost about 5 ounces of fluid out the back of the trans. Was it over filled or am i now under filled???
I cant picture the height of the fill hole relative to the tail shaft.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 12, 2010
  • Sep 12, 2010
It's underfilled now. You can actually pull the driveshaft out without loosing any fluid, but you have to raise the back end of the car up quite a bit over the front.
Kurt
Adam95GT
2,564
Burlington, NJ
Sep 12, 2010
  • Sep 12, 2010
Kurt
It was level on a lift. Guess i need to add some fluid.
toyman
1,944
54
79
Vernon BC
Sep 12, 2010
  • Sep 12, 2010
On the assumption that you are not filling it removed from the car, and you are not, you can only fill to the bottom of the fill hole. So if fluid does not come out when the plug is removed it's under filled. However, 5 oz one way or another probably doesn't really matter.
Adam95GT
2,564
Burlington, NJ
Sep 12, 2010
  • Sep 12, 2010
Yep but while i have the access to the lift i might as well crack it open and see if it drains out the fill hole. If not ill just fill it untill it starts to leak out the fill hole....
Or should i drain the whole thing and refill?
toyman
1,944
54
79
Vernon BC
Sep 13, 2010
  • Sep 13, 2010
The decision to empty and replace will depend upon factors that only you know about. Such as, has it been sitting in there for years or has it seen lots of miles since it was last changed. Of course, peace of mind says just change it. It's less than 3 quarts (2.6L)
Adam95GT
2,564
Burlington, NJ
Sep 13, 2010
  • Sep 13, 2010
ITs been in there for about 200 miles...
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 13, 2010
  • Sep 13, 2010
Yeah, while you have a lift, it's a perfect time. If you pull the driveshaft out while the car is level, it will fall below the recommended level.
Kurt
C
Trans issues.
  • ChrisCruz1972
  • Aug 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
slow84lx
P1450 issue 2015 ecoboost pp
  • matthewt
  • Apr 19, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2K
2015 - 2023 (S550) Mustang -General/Talk Apr 22, 2025
90sickfox
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
D
Brand New C6 Transmission Pouring fluid
  • Danielperry2003
  • Jun 17, 2025
  • Other Auto Tech
Other Auto Tech Jun 17, 2025
General karthief
