I just got an ATI procharger d3m blower. I did not know anything much about it when I bought it (obviously) I called tech support to run the serial # and found out this thing is friggin HUGE. I have a basically stock motor right now, nothing too special just intake, TB, headers, no cam, stock heads, etc. The blower puts out like 22lbs. I was told that it is capable of like 1200hp. A bit overkill for me I have an 86 vert. Even if I turned it down the farthers I could get it down would be like 12-13 PSI I was looking more toward the 6-9 range for now. I am open to suggestions on where I could get rid of this anyone know of any high HP forums around, I attached a copy of the add I have up in classifieds right now
Description: Brand new ATI procharger d3m blower, full kit did not come with an intercooler does have:
D3 BLOWER SATIN SERIAL #80432
MAIN BRACKET
SUB BRACKET COG IDLER PULLEY w/ BEARINGS
6 RIB IDLER
6 RIB SERPINTINE IDLER BRACKET
WATER PUMP PULLEY
CAST ALTERNATOR BRACKET
SS ALTERNATOR BRACKET STRAIGHT
SS ALTERNATOR TENSIONER BRACKET
8MM COG CRANK PULLEY
8MM COG BELT
6 RIB SEPERTINE BELT
OIL FEED LINE
OIL RETURN LINE
OIL RETURN AND FEED FITTINGS
ITS ALL HERE - ALL NEW AND NEVER USED !
I don't know a whole lot about this I bought it and it is WAY too big for me to use. I will consider trades for engine parts (heads) maf AND INJECTORS other superchargers. I will not consider trades for other vehicles, body interior driveline etc. Please E-mail me offers This is not gonna be given away so please don't waste my time with stupid trades or lowball offers
MAIN BRACKET
6 RIB IDLER
WATER PUMP PULLEY
8MM COG BELT
OIL FEED LINE
OIL RETURN LINE
