Most of you may already know this but if you plan on getting an O/R H pipe ( and you should)
Just remeber you will need Oxygen Sensor Extensions becuase Ford redesigned the location of the rear oxygen sensors on the 2004 Mustang and oxygen sensor extensions are required to install any aftermarket H or X-pipe
Also if your installing Longtube headers which move the location of the front oxygen sensors further back and the factory wiring on your Mustang's front oxygen sensors are not long enough to reach the new location.
I had to find out the hard way just wanted to give you guys a heads up
TampaBay 04 GT
!Just remeber you will need Oxygen Sensor Extensions becuase Ford redesigned the location of the rear oxygen sensors on the 2004 Mustang and oxygen sensor extensions are required to install any aftermarket H or X-pipe
TampaBay 04 GT
