onebad95 Sherriff of Bling King County Jul 22, 2002 1,237 0 37 At the end of the track waiting for you !! Sep 11, 2004 #1 Sep 11, 2004 #1 When you put your x2c fox conversion kit on, what did you do to replace the vacuum tree that is on our stock elbow set up ???
GTJake Founding Member Oct 28, 2002 3,049 0 56 Ann Arbor, MI Sep 11, 2004 #2 Sep 11, 2004 #2 I put a vaccum connection under the lower intake and spliced a three-way in with the vaccum line that goes to the canister on the passanger side for the fuel pressure regulator. The vaccum line for the brakes went under the lower intake. Jake
4Jenna Founding Member Sep 12, 2001 4,326 6 69 AZ Sep 13, 2004 #3 Sep 13, 2004 #3 All mine run off the manifold...plus i have no EGR.
