  • 1994 - 1995 Specific Tech
Attn: Killer Paul
  • Thread starter Thread starter badingle
  • Start date Start date Apr 22, 2005
badingle
127
Portage, Michigan
Apr 22, 2005
  • Apr 22, 2005
hey man, I just put in my PA racing K member and my passenger side motor mount isnt not lining up. The bolt goes in but the allignment stud is about 1/4" off. I have energy suspension mounts.
I know you just installed one, Did you run into this too?
-Andy
Killercanary
The car that set the bar.
Altoona, PA
Apr 22, 2005
  • Apr 22, 2005
If you are refering to the little "pin" in the motor mount all you need to do is take the motor mount apart, cut the weld, and knock the pin out. Its very easy to do. Hope that helped. I have poly motor mounts as well.
badingle
127
Portage, Michigan
Apr 22, 2005
  • Apr 22, 2005
Thanks Paul!!! That will do it. I wasnt sure if that was a needed item or not.
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Apr 22, 2005
  • Apr 22, 2005
I'm so confused!
badingle
127
Portage, Michigan
Apr 22, 2005
  • Apr 22, 2005
super302 said:
I'm so confused!
super302
May 29, 2004
2,878
Davenport, IA
Apr 22, 2005
  • Apr 22, 2005
badingle said:
D
DARK-5.0
724
Leawood, KS
Apr 23, 2005
  • Apr 23, 2005
Makes plenty sense to me
Jeremy
YEAHLOH95
1,249
EVERETT,PA
Apr 23, 2005
  • Apr 23, 2005
there is an alignment pin on the motor mounts ,that hits on the k-member ,and won't let it sit flush ,so youhave to remove it .
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
