  • Mustang Sound & Shine All
Audio Experts....Got a question
  • Thread starter Thread starter jzleach1
  • Start date Start date May 27, 2004
jzleach1
535
Westminster, Maryland
May 27, 2004
  • May 27, 2004
Okay, I installed a Kenwood Excelon KDC-X469 and JL Audio 4-channel amp a little over a month ago. Everything went fine on the install and I really enjoy the new sound.
The problem I'm having started a couple weeks ago and for the life of me I can't figure out why it is doing this. The problem is that whenever I am driving and I make a left hand turn the sound will cut out for a second or two. The amp will come back on and everything is good until I make another left had turn. The sound will cut out no matter how slow or fast I am going and it doesn't matter how much of a turn I make, even lane changes.
I've retraced all the wiring, checked my amp's power and ground and everything looks good. I don't think it's the main power as my Bazooka amplified tube cuts out as well. Both components share the same grounding location and amp turn on lead. My head unit does not cut out, it stays powered up. Any thoughts here?
85GTlover
704
  • May 27, 2004
You say you checked all wires and connections.......that is what I figure it would be......somewhere a wire is loose or grounding out, or there is a loose connection or bare part of a wire causing it I would think.
Infinity
956
Charlestown, IN
May 27, 2004
  • May 27, 2004
Temporarily run new patch cords to the amps. Just toss them through the interior and then drive around. I'd bet there's your problem.
Infinity
956
Charlestown, IN
May 27, 2004
  • May 27, 2004
Oh, forgot. Also, run a new remote turn-on lead. You have a wire that's temporarily losing connection somewhere, and you need to figure something out. Are the amps/tubes staying on and losing signal, or are they cutting off altogether.
jzleach1
535
May 27, 2004
  • May 27, 2004
Thanks for the info fellas. I'm guessing it is the remote turn on lead. While driving this afternoon I noticed that when I shift in my seat the sound cuts out. So now I know where to start looking. I'm guessing that one of my wires is too close to my mounting bolts and making contact with them and grounding out. I'll remove the seat and carpet and take a look. Again, thanks!
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
T
Need advice: 93 Cobra audio upgrade with no permanent modifications
  • THNX SVT
  • Feb 18, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2024
TIGGER
