This is a link to an article on the swap. I'm not sure if you can access the whole article without a subscription, but I know one of the car magazines did an article on it last year and a search will probably come up with the info on it. By far the hardest part is the pedal assembly. Everything else is straight forward.
I may get flamed for this, but before you go and spend the money on a swap. Consider what the AOD can do. It can take a decent beating and when built right (check mods in my sign) It can run with the manuals. With a manual valvebody you can out run some of the best stick drivers. Check out http://www.clickclickracing.com for info on how to make an Auto Stang fast.
