Auto trans stalls in gears
Robs96
131
I have a 95 that I recently replaced the iac on due to high revs. The car idles fine now but stalls when it is put into drive or reverse. If I put it in gear with my foot on the gas it will run but when I stop it immediately stalls out. This is a new one to me. Any ideas?
Could be alot of things.
I would just reset the eec by unhooking the battery and seeing if it continues.
Then I would check for vacuum leaks.
Then I would do voltage tests on all the sensors.
Then I would check compression on each cylinder.
Then I would check for exhaust leaks/obstructions.
If you got the IAC from AutoZone, that's probably the problem. Never get AutoZone electric components.
