auto ?
vipergt
47
ok if im on the interstate going 70-75 with overdrive off im turning i think about 3500rpm. when i go wot the rpm's actually drop 200-300 rpm for a second before starting to climb. secondly is there a way to program the comp to drop the tranny into second at that speed when overdrive is off? i have to manually drop it into second at that speed i think rpms are about 4700 rpms though, then i throw it into D. I know its not the best thing for the car but in race situations the car seems to have alot more pull. i know someone may say should of bought a manual but i have a phobia about used cars and no new manuals were available that i could find, plus i got a brand new gt for 19k.
it sounds like the torque convertor is unlocked when you are in third then locks when you go WOT. that would explain the RPM drop.
yes. tho it doesn't matter if the car is in 3rd or 4th.
vipergt said:
is it normal for the torque converter to do this? second, how do you program the tranny to do this, my pred want do it
you'll have to get a new tune. the predator won't do it for you. i can program mine to do whatever i want because i have the SCT pro racer package. any professional tuner should be able to do it for you. as far as the torque convertor, it depends. if you haven't been in 3rd long, it's normal for it to be unlocked for a few seconds if it just shifted or you are heavy on the throttle. but if you were just cruising in 3rd for awhile, it should be locked.
