autolite 25 problems
  • Thread starter Thread starter DCjuggalo
  • Start date Start date Dec 13, 2004
DCjuggalo
169
Charlotte, NC
Dec 13, 2004
  • Dec 13, 2004
does anyone use the autolite platinum 25's ? ???
i bought them for my 88 302, i wanted to get 24's like u guys talk about but pep boys said the 25 was what i needed.
so anyways i cant get them to fit, i tried for about 10 minutes and gave up. the thread want even catch.. then i put the old ones back in.
281pony
2,681
Oly, WA
Dec 13, 2004
  • Dec 13, 2004
im not familiar with the platinum plugs, are the bodies any different then the standard plugs?
i used autolite 25's with no problems. what kind of heads do you have?
DCjuggalo
169
Charlotte, NC
Dec 13, 2004
  • Dec 13, 2004
as far as i know they're stock e7 heads..
i compared the 2 plugs when i had it out and the diameter of the ap25 plug right above the threaded section is alot bigger
damn can't take em back tho cause i threw away the receipt
87fcoupe
57
  • Dec 13, 2004
First all you don't want platinum.Second autolites 25 is correct plugs if you have stock heads.Look and make sure they are autos 25 NOT 3925's ok.
HISSIN50
34
129
Dec 13, 2004
  • Dec 13, 2004
efi 5.0's seem to like copper plugs. some people have idle and high rev issues with plats (plat does not conduct nearly as well as copper).
tonydalrymple
167
29
39
Salt Lake City, Utah
Dec 13, 2004
  • Dec 13, 2004
Agreed. Last year I installed platinum plugs. 500-600 miles afterward; i developed a higher rpm miss. I found dozens of threads of people with platinum plugs & issues. I swapped in regular Autolite #25's & the problems went away....
HISSIN50
34
129
Dec 13, 2004
  • Dec 13, 2004
exactly. often the idle is a bit low with plats and people get a high speed misfire (often around 4K-4.5K rpm).
PNY PWR
522
Wichita, KS
Dec 14, 2004
  • Dec 14, 2004
Never use platinum plugs unless the motor calls for them or came with platinums from the factory.
You want either the regular Autolite 25's or Motorcraft ASF42C's.
W
wagnermotors
  • May 7, 2010
25
i had this same problem but it was with my f150 it was due to the headers i had on there the fatter part of the plugs rubs up on the headers i had to use autolight 2545 they are from the crown vic of the same year and motor my f150 was also a 88
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,115
224
Massachusetts
May 7, 2010
#10
  • May 7, 2010
  • #10
Don't use autolites Get the motor craft oem copper plugs. The specs are tighter.
281pony
2,681
Oly, WA
May 8, 2010
#11
  • May 8, 2010
  • #11
wow... 6 year old thread revival?
didn't know i was on this forum back in 04' lol.
MustangLX-5.0
856
Lehigh Acres Fla.
May 8, 2010
#12
  • May 8, 2010
  • #12
Motorcraft plugs FTW. Never had such a smooth running engine til I used Motorcraft plugs. Forget Autolites.. those things are garbage. Always ran into some kind of trouble later on whenever I used those. Not enough copper in them .. if any, I would assume. Best bet, use what was meant for this engine.... after all, Ford makes them.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
R
New to forum and new to mustang ownership
  • Ragged
  • Mar 23, 2025
  • The Welcome Wagon
The Welcome Wagon Apr 21, 2025
My Unicorn
M
