  • SN95 4.6L Mustang Tech
Automatic what kinda mods to do?
  • Thread starter Thread starter Cantslowdown
  • Start date Start date Feb 7, 2006
1 of 2 Next Last
Cantslowdown
502
Mt.Home AR!
Feb 7, 2006
  • Feb 7, 2006
I just got a 99 mustang it has 109,000 my mom has taken really good care of the stang and now its my play toy. So what kinda things can i make it shift faster.. I was thinking a progamer..
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Where the men are men and the sheep are nervous
Feb 7, 2006
  • Feb 7, 2006
Transmission cooler
J-mod (For the 99 and newer 4R70Ws go to www.crownvic.net, click tech
articles and click4R70W late model transmission upgrade)
3.73 gears and higher
I like the SCT Xcal 2, check around in your area to see what tuner different shops are using.
Cantslowdown
502
Mt.Home AR!
Feb 7, 2006
  • Feb 7, 2006
My pc is being dumb and wouldnt let me access that..
san~man
O-G
A little grass shack on a big lava rock
Feb 7, 2006
  • Feb 7, 2006
www.tccoa.com and look under tech/transmission/modifing valve body to Jerry's specs.
Cantslowdown
502
Mt.Home AR!
Feb 7, 2006
  • Feb 7, 2006
so what all dose the j-mod do..
GREENBIOCH
1,241
In an Igloo
Feb 7, 2006
  • Feb 7, 2006
So what would be the difference in the J mod as opposed to firming up the shifts with a tuner such as the Xcal2? is there a difference? can you do both or is one better than the other, anyone with experience from one or the other or both i would like to hear from?
obviously a tranny cooler is required if doing one of these. or i would hope that that would be an item on your shopping list when messing with an auto tranny.
Bubba Z.
88
Tallahassee, FL
Feb 7, 2006
  • Feb 7, 2006
Four things no automatic transmission should be without:
1. Shift kit such as the J-mod to firm up shifts
2. High stall torque converter 2600-3200 RPM
3. Transmission cooler
4. 4.10 gears
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Feb 7, 2006
  • Feb 7, 2006
as was said above, as well as use Amsoil Mercon V fluid. also get the E150 pan. its a deeper sump and has a drain plug in it. heres the part number F8UZ-7A194-AA
also consider putting in an inline trans filter. when you do drop the pan, put in a new screen filter.
Cantslowdown
502
Mt.Home AR!
Feb 7, 2006
  • Feb 7, 2006
Ohh yes i am looking to buy a tranny cooler and temp gauge. But whats the dang j-mod i see how u do it but what dose it do...
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Feb 7, 2006
#10
  • Feb 7, 2006
  • #10
read the transmission articles at www.tccoa.com it will answer all of your questions
like everyone said, best thing is to go for a 2800+ stall converter, tranny cooler, J-mod and 4.10s.
Cantslowdown
502
Mt.Home AR!
Feb 7, 2006
#11
  • Feb 7, 2006
  • #11
Well a tunner help any cuz it will prob be awhile for the j-mod..
the98stang
2,408
Clovis, CA
Feb 8, 2006
#12
  • Feb 8, 2006
  • #12
Tuners are always nice
propellerhead
1,541
"but what's with the but shots?"
Feb 8, 2006
#13
  • Feb 8, 2006
  • #13
With a tuner, you can undo the mod. And you can keep adjusting the shift firmness as many times as you want until you find the settings you like. With the jmod, you're done. Unless you crack the transmission open again and almost do the jmod all over again.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Feb 8, 2006
#14
  • Feb 8, 2006
  • #14
well if it's going to be a while for the J-mod then the tuner will do just fine because you can adjust until you find the setting you like
propellerhead
1,541
Feb 8, 2006
#15
  • Feb 8, 2006
  • #15
The Xcal2 has more adjustable settings for automatics than the Predator.
T
TGJ
1,049
#16
  • Feb 8, 2006
  • #16
If it was me, I would do in this order:
1) J-mod and Tranny Cooler, flushed and refilled with Mercon V
2) Torque Converter
3) Handheld flasher unit
Cantslowdown
502
Mt.Home AR!
Feb 8, 2006
#17
  • Feb 8, 2006
  • #17
thanks guys welp i prob hava a tuner on the way see how it gose..
propellerhead
1,541
Feb 10, 2006
#18
  • Feb 10, 2006
  • #18
2) Torque Converter
I did 3, then 1 without the jmod, then 2. Doing #3 first set me up when I got 4.10s and an offroad midpipe. I didn't need a SpeedCal or MIL Eliminators.
san~man
O-G
Feb 11, 2006
#19
  • Feb 11, 2006
  • #19
2) Torque Converter
You forgot gears.....
cantslowdown...
If it's going to be a while until you get the Jmods, do this:
Trans cooler
Programmer and 4.10's (assumingyou're going to stay N/A)
Then you can do the T/C and the JMod once the tranny is all opened. No sense opening it up twice and filling fluid twice.
Cantslowdown
502
Mt.Home AR!
Feb 11, 2006
#20
  • Feb 11, 2006
  • #20
San ~man what mods do you have and what times are u running in the 1/4..
With 4.10s how bad dose the mpgs drop..
1 of 2 Next Last
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
Opinions on a possible project car w/ pics
  • Teen'93stang5.0
  • Mar 29, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Mar 30, 2026
Teen'93stang5.0
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
