  • SN95 4.6L Mustang Tech
Autometer Lunar gauge install
  • Thread starter Thread starter 1fast03pony
  • Start date Start date Jul 25, 2006
1fast03pony
749
New york
Jul 25, 2006
  • Jul 25, 2006
Guys,
Im installing my autometer lunar gauges.. I have three of them. Its a straightforward install, however, to power and dim the LED backlights int he gauges, I must tap into the 12V dash lighting wire and the Ignition wire. I cant seem to get proper access to the wires behind the fuses under the dash, so would it be acceptable for me to just tap the fuses corresponding to the 12V and ignition? I did this with one gauge, and it works great, but im afraid to tap them with two more wires. Will this overload the fuses?
Dope 97GT
439
Rochester, NY (SUNY Brockport)
Jul 25, 2006
  • Jul 25, 2006
I dont think so I have 5 gauges all running from the fuse box off the same one and they work fine.
saleen556
387
Hillsboro,OR
Jul 25, 2006
  • Jul 25, 2006
You shouldn't have any problem running them all off 1 ign wire.I have had 4 running off 1 for quite a while with no problems.The wire for the lighting can be spliced in to the blue/white stripe wire off the dimmer fuse #37 I believe or the back side of the headlight switch.
bryan0
175
Bethel, CT
Jul 25, 2006
  • Jul 25, 2006
saleen556 said:
...The wire for the lighting can be spliced in to the blue/white stripe wire off the dimmer fuse #37 I believe or the back side of the headlight switch.
yea, in the manual it's called "adjustible illumination" go to autozone and get one of those fuse tapper things, makes it SUPER easy.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Autometer 3318 Fuel Gauge
  • cbac89
  • Apr 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2025
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
