Haha.
Well, the fuse taps are just little plastic things, where one end contains the fork connector that plugs in to the fuse box, then on the other end there is a fuse (you remove the stock fuse, and plug it on to the fuse tap.)
Then, there's another spot for a fuse, and a wire sticking out. You run your wire from the gauges to that wire, and pick whatever rating fuse is appropriate (can't remember offhand which ones I used.) Basically, it allows you to run the stock fuse, while running a fused splice off that one.
They have them at Autozone in the aisle that sells the fuses.. I use them in all my vehicles, for one, I hate splicing in to factory wiring (it broke my heart installing the speedcal,) and 2, sometimes I can't find what I'm looking for without removing tons of trim pieces.
A good example is on my wife's ZJ, I was trying to find a 12v ignition on source for an oil pressure gauge, without pulling the radio, so I just ran a wire inside the factory bundle under the dash to the fuse box (which on the ZJ is under the passenger side kick panel) to a fuse tap.
No wires showing, no splicing, no worry of bad wiring jobs, etc.
