Autometer Sport-Comp lighting
  • Thread starter Thread starter 01PonyGT
  • Start date Start date Nov 7, 2005
01PonyGT
304
Willow Grove, PA
Nov 7, 2005
  • Nov 7, 2005
Anyone have any experience with Auotmeter Sport-Comp gauges at night? They have "around the dial lighting" as opposed to some of the more expensive gauges (cobolt, lunar, C2) that have "through the dial lighting". I had the Lunar gauges in my 2001 GT and visibility was not a problem at night. I'm going for a more subtle/classic look in my '91, but am concerned about night-time gauge visibility. Any experiences?
Thanks,
WES
jd-hart
124
Greensboro, NC
Nov 7, 2005
  • Nov 7, 2005
I put 3 of the Autometer Sport Comps under my radio and they work great. I used the green bulb cover and it matches my dash good.
No complaints here.
01PonyGT
304
Willow Grove, PA
Nov 7, 2005
  • Nov 7, 2005
No complaints here.
So the lighting is bright enough for you? I'll be replacing the instrument cluster in the dash with all Sport-Comps.
Also, what gauges did you put under the radio. I have a plate that will mount a DIN size radio and three 2 1/16" gauges under it. I was a little worried about the viewing angle being bad.
WES
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Nov 7, 2005
  • Nov 7, 2005
I have ultra-lite gauges in my car and I can see everything perfectly at night. I tried some of those blue bulb covers to match my reverse glow stock gauges, but it made it too dim to see at night. But when the bulbs are normal, no complaints.
jd-hart
124
Greensboro, NC
Nov 7, 2005
  • Nov 7, 2005
I used the water temp and oil pressure mechanical ones. I also have the volt meter one. I did it so all my stock gauges still work.
I used the angle pieces you can get from autometer so the gauges are angled towards the driver. It took a little work to get them to fit with the angle and all, but well worth it once it was done. I have no problems at night with the bulb covers. It gives it a nice green glow.
vristang
4,933
101
124
Seattle
Nov 7, 2005
  • Nov 7, 2005
I also have a few sport comps. The birightness was too much for me witohout the green bulb covers on. Put the bulb covers on and it is a great match to the rest of the interior. If you are not happy with the brightness, you could swap out the bulbs? I am pretty sure they are a standard type.
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
A
Engine Turbo 5.0 Mustang bad misfire at WOT
  • AwxyMoron
  • Apr 3, 2021
  • 2 3
10K
Fox 5.0 Mustang Tech May 5, 2021
a91what
Sold my 94 GT convertible and buyer calls me next day with an issue
  • Lawdawg86
  • Dec 20, 2020
3K
1994 - 1995 Specific Tech Dec 20, 2020
Lawdawg86
New Gauges...Accurate? Well Made? Safe?
  • Wayne Waldrep
  • Oct 18, 2019
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2019
jrichker
Diy 87-93 Mustang Instrument Cluster Led Upgrade And Triple Guage Pod Install
  • stang89bidges
  • Nov 30, 2015
20K
Fox 5.0 Mustang Tech Aug 11, 2024
Mindseye007
