ok....sensor works by reading just the one side right?....thanksYes, the collector is part of the header.
Some guys do put it in the xpipe, others say not to. Most companies suggest a distance from the exhaust port for accurate readings, that distance tends to put the xpipe too far away to install the sensor there. It's a debatable subject, but you'll be fine where its at now.ok....just was making sure it didnt have to be in the x pipe or somthing to read both sides....its welded in and working now
quick question,i have long tubes,it says to drill and install the sensor to the collector,so that would be on the header correct?...the sensor is fine just reading the one side?...
thanks just want to make sure
Which one have you seen that plugs directly into the fox harness? The connectors for the wideband are totally different.Did you get one that plugs directly into our O2 harness?
Edit: I'm about to tackle this soon but I have the Innovate LC-1
With the AEM 30-2310, you can cut the pigtail off your old O2 sensor and hook it up to your wideband O2 sensor and then plug it directly into your factory O2 harness.
Edit: Sorry I had time to think. This is typically used with a stand alone ECU. Nevermind.
You can do this without a stand alone system.
