AUTOMETER!!!!!!!!!
  • Thread starter Thread starter beans72
  • Start date Start date Jul 6, 2007
beans72
23
  • Jul 6, 2007
Would somebody please tell me how difficult it is going to be to wire up my new autometer tach and shift light? Is it a long process? Any tips or anything?
Thanks,
Brandon
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jul 6, 2007
  • Jul 6, 2007
green - coil neg
red - pos current from switch
white - dash light
black - good ground
pretty easy stuff, just follow the instructions
beans72
23
  • Jul 6, 2007
well im not sure if their is going to be instructions because im buying it used....but i figured it couldn't be too hard...are all the wires behind the instrument panel?
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Jul 6, 2007
  • Jul 6, 2007
your conna have to run new wires, tap power from the ignition switch for the red wire, and the white wire, go to the lighting switch to turn on the headlights, the green goes to the negative side of the coil, and the black goes to a nice engine ground.
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Jul 6, 2007
  • Jul 6, 2007
You can download the PDF instructions from the autometer website
The coil wire will have to pass thru the firewall or you can find it on the computer pin (not sure which one though).
I used a wire in the steering column (remove plastic case, 3 screws) that provides +12 volts at ignition (use a multimeter or test light to find the wire).
Dash light, you can tap into the light that goes to the HVAC controls
Ground, well ground it onto the firewall (under the dash)
beans72
23
  • Jul 6, 2007
so are all these wires going to be easy to find when i take the instrument panel off???
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Jul 6, 2007
  • Jul 6, 2007
don't need to remove the inst. panel for the wires. The ignition wire can be found in the steering column (only need to remove that housing). I tapped into the light in my HVAC control since it was close and easy to find (pull out light, add wire to (+)).
beans72
23
  • Jul 6, 2007
ok that sounds a lot easier than i thought it would be...thanks man!!
Interior and Upholstery HVAC Mode selector vacuum switch issue.
  • parish99
  • Jul 3, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
KAWMAN2
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
