  • 1994 - 1995 Specific Tech
Autozone Code Scanners not Work
  • Thread starter Thread starter IEatRiceGT
  • Start date Start date Jun 9, 2006
1 of 2 Next Last
I
IEatRiceGT
150
MD
Jun 9, 2006
  • Jun 9, 2006
So I went to two Auto Zones to scan for codes to see why my check engine light randomly goes on and off. Both scanners came back with a operator connection error or something. Does this mean my computer plug(under the dash) is messed up? Will the paperclip or manual method be the only way to pull codes now? Thanks.
OrangeMustangGt
1,976
Cape Cod, MA
Jun 9, 2006
  • Jun 9, 2006
that plug goes to nothing. you must use the obd1 port under the hood on the pass side to pull codes
T
toppdogg_1
89
  • Jun 9, 2006
Using the wrong code port, there is on the the Passenger side under the hood, it's clipped behind the strut tower mounting area
I
IEatRiceGT
150
MD
Jun 9, 2006
  • Jun 9, 2006
....f'ing nOobs at Autozone. Thanks guys, I'll go back there tomorrow.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jun 9, 2006
  • Jun 9, 2006
They probably thought your car was a 4.6, lol.
Aren't those (OBDII's) under the dash?
Blackened302
1,439
South TX
Jun 9, 2006
  • Jun 9, 2006
screw autozone--they still count blinking lights. go to advance--they have a digital OBD-I reader and it even prints out the codes on a nice little receipt, too!
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jun 9, 2006
  • Jun 9, 2006
Here a little info for anybody who goes to AA to get scanned. After they hook up the reader they MUST plug the scanner either up to the battery or the cig lighter plug or it will NOT work. I worked at AA for a bit and it took me a bit to figure out why it wouldn't read, it need another source of power for it to work.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jun 9, 2006
  • Jun 9, 2006
My buddy who worked at AA never had to do that.
P
Pennywise2
Banned
May 16, 2006
1,379
  • Jun 10, 2006
The employee's at Autozone know nothing that is why I don't shop their.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jun 10, 2006
#10
  • Jun 10, 2006
  • #10
The scanner we used need a seperate power souce to read obd1 systems. This wasn't some junt scanner either I'm pretty sure it was Acron(sp?).
I
IEatRiceGT
150
MD
Jun 11, 2006
#11
  • Jun 11, 2006
  • #11
Okay...I meant to say that I went to advanced auto for the scanner in the first place. I thought that 95's were obdII so hooking it under the dash is the correct place, isn't it? So what could my problem be?
HISSIN50
34
129
Jun 11, 2006
#12
  • Jun 11, 2006
  • #12
If you have a GT, forget you ever saw that OBD-II connector inside the car. You use the connector on the passenger side of the engine compartment (between the pass strut tower and the firewall). And you an OBD-I reader (or a jumper wire). Again, your GT is OBD-I.
Good luck.
P
Pennywise2
Banned
May 16, 2006
1,379
#13
  • Jun 11, 2006
  • #13
Good luck.
HGFireHazard
460
Michigan
Jun 11, 2006
#14
  • Jun 11, 2006
  • #14
94 and 95 V6 stangs were OBD-II if my memory serves me correctly, but our cars were not until 96.
I
IEatRiceGT
150
MD
Jun 11, 2006
#15
  • Jun 11, 2006
  • #15
I thought my 1995 GT was obdII...that's what the dyno said when I inquired about getting a chip burned.
HGFireHazard
460
Michigan
Jun 12, 2006
#16
  • Jun 12, 2006
  • #16
A lot of people are misinformed about a lot of things on our cars... even Ford. They told me that my car had 4 O2 sensors. Hissin and everyone else is right, trust us!
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Jun 12, 2006
#17
  • Jun 12, 2006
  • #17
OB1.
J/K ... but yeah, it's for sure OBD I.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jun 12, 2006
#18
  • Jun 12, 2006
  • #18
94/95 V6's are obd11 ALL 87-95 5.0 V8 are obd1 no exceptions.
I
IEatRiceGT
150
MD
Jun 12, 2006
#19
  • Jun 12, 2006
  • #19
So the plug under the dash should have worked then? The plug in the engine bay doesn't look like it would even fit the same scanner plug.
9
95yellowGTS
41
Pope AFB, NC
Jun 12, 2006
#20
  • Jun 12, 2006
  • #20
NO. As stated before, FORGET THAT STUPID PLUG UNDER YOUR DASH. Pretend it's not even there. The plug under the hood is the one you need. It will NOT fit an OBD2 scanner, as your car is NOT OBD2. Do a search, use a paperclip, and get your own codes. Easy as pie.
1 of 2 Next Last
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
