  • 1994 - 1995 Specific Tech
Autozone Code Scanners not Work
  • Thread starter Thread starter IEatRiceGT
  • Start date Start date Jun 9, 2006
First Prev 2 of 2
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jun 12, 2006
#21
  • Jun 12, 2006
  • #21
That's why the plug under your hood didn't work. The scanner you were using is for OBD II! Get an OBD I scanner or use a paper clip. Use plugs under hood on passenger side. Remember, there are two plugs that you'll have to plug in. A large one and a small one. Once again, forget about the under dash plug. If you don't believe us .... pull out your Hayne's or Chilton's manual & look for yourself ... or do a search online.
L
lparsons
20+ Year Stangneter
May 24, 2004
198
Upstate New York
Jun 13, 2006
#22
  • Jun 13, 2006
  • #22
IEatRiceGT said:
So the plug under the dash should have worked then? The plug in the engine bay doesn't look like it would even fit the same scanner plug.
If you search around, you should be able to find a ford OBD-I scanner fairly cheap. I think I got mine for less than $40 online. It runs on a 9V battery and reads both the engine codes and the ABS codes.
Here's one I found through froogle.google.com:
http://froogle.google.com/froogle_u...W2r-AowSJzsT95oQ80SKTvAAAAAAAAAAA&gl=us&hl=en
Notice how much different the plug is for that one than the OBD-II scanner the guys at the stores tried to use. Most stores in my area don't even want to (or have the ability to) read OBD-I codes anymore.
FWIW, our 5.0's have two ports in the engine bay, which both work with OBD-I readers. One is engine codes (on the passenger side) and the other is ABS codes (on the driver's side, near the fuse box).
L
lparsons
20+ Year Stangneter
May 24, 2004
198
Upstate New York
Jun 13, 2006
#23
  • Jun 13, 2006
  • #23
PS:
Don't be an idiot (like me the first time) and forget to turn your car off when you're done reading codes. Otherwise you'll have a code and a dead battery
Methodical
1,192
11
59
Clinton, MD
Jun 14, 2006
#24
  • Jun 14, 2006
  • #24
lparsons said:
PS:
Nah, you weren't an idiot, you were just elated with being able to read your own codes and got excited when all was well and forgot to turn the key.
Someone with your signature is most likely not an idiot.
Peace
First Prev 2 of 2
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
