  • 1994 - 1995 Specific Tech
Autozone IAC.
  • Thread starter Thread starter 94GTCoupe
  • Start date Start date Dec 12, 2008
1 of 2 Next Last
94GTCoupe
1,412
92
79
CA
Dec 12, 2008
  • Dec 12, 2008
anyone have any experiance with the IAC from autozone?is it a good peice?it cost about $60 compared to the motorcraft at over $100.
also whats the differance between the 5.0 IAC and the v6 IAC?
are they interchangable?
looking on the website,they have differant part #'s.
i can pick one up for cheap,if it will work.
Thank's,
-Davis3.
greenlantern
265
St Louis Mo
Dec 12, 2008
  • Dec 12, 2008
Are you nuts??
With all the problems a bad IAC can cause on these cars, you wanna buy one from autozone.
If you need air filters, car wax, tireshine, airfreshners, oil or filters go to autozone. If you need anything electronic or anything else for that matter go somewhere spend the money and get good parts.
AUTOZONE???
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Dec 12, 2008
  • Dec 12, 2008
I have to agree with greenlantern, I always buy certain sensors (such as the IAC or TPS) from Motorcraft. I've had a off-brand IAC fail in under a year, while the Motorcraft replacement has lasted several years. The two IAC's were literally identical except the Motorcraft one had a Ford logo stamped on it. I would guess that Ford has higher standards that their parts must pass. Parts that don't pass end up getting sold under a different brand.
While the Autozone IAC may be cheaper, you may end up paying more money in the long run if you have to buy two or three before the Motorcraft one would have failed.
94GTCoupe
1,412
92
79
CA
Dec 12, 2008
  • Dec 12, 2008
thank's guy's.
good to here from someone with first hand knowledge
called the dealer,they want $170 for one,plus they will have to order it.
i've seen it online for less.$113 at rockauto.com
any recommendations on where to get one?
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Dec 12, 2008
  • Dec 12, 2008
RockAuto.com is always good for prices. LateModelRestoration has the Motorcraft sensor for $125, so RockAuto seems your best bet.
94GTCoupe
1,412
92
79
CA
Dec 12, 2008
  • Dec 12, 2008
how about this?
Buy Ford Racing Parts!
i know it cost more,but it's a new throttle body w/the IAC.
D
DarkStallion095
93
Rancho Santa Margarita, CA
Dec 12, 2008
  • Dec 12, 2008
Kragen
I bought one from Kragen Auto parts, youre in calif. so you shouldn't have a problem finding one...but anyway it was like 80 bucks and it was made from an aftermarket manufacturer judging by the box, but it had a ford emblem on it and a ford part number. And it worked perfectly. Let us know which you go with. So the one I got from Kragen is working great after a year.
94GTCoupe
1,412
92
79
CA
Dec 12, 2008
  • Dec 12, 2008
i think i'll try cleaning my old one and resetting my idle per RJ's instructions tomorrow.
i welcome more first hand opinions on the non-Motorcraft IAC's,before i decide.
thank's,guy's
94GTCoupe
1,412
92
79
CA
Dec 13, 2008
  • Dec 13, 2008
cleaned the hell out of the throttle body and IAC,aswell as the MAF today.
used carb cleaner on the IAC,than sprayed it out with brake cleaner.
from the throttle body,i removed the IAC adjustment screw.you should have seen how gummed up it was.soaked it in carb cleaner,gave it a little scrub with a scotch brite pad,than cleaned it off with brake cleaner.
on the throttle body,i stuffed it full of shop rags,than in the IAC air passages,i scrubbed it out with a small brush and sprayed brake cleaner in there to clean it out.let it dry.
disassembled the MAF housing,removed the sensor and sprayed it down with brake cleaner.
i let everything dry than reassembled with a new throttle body gasket and IAC gasket(only Napa(#735-3509,$6.36) carried the gasket by itself,Autozone,Kragen,and Pepboys only sold the gasket with a new IAC).
also added two hose clamps to the valve cover vent hose that leads to the intake tube.felt very loose,did not want to suck in any unmetered air.
reset idle per RJ'sniceinstructions.(fourth post down.)
http://forums.stangnet.com/759024-idle-problem-please-help.html#post7590041
idle's good(around 700 RPM),no surging drove around town for about a half hour with the heater on.no stalling/dying at stop lights,or check engine light.
i hope this solved my issue.
saleener94
153
Compton,CA
Dec 13, 2008
#10
  • Dec 13, 2008
  • #10
I tried an autozone IAC once. It didn't work. Autozone guy didn't want to exchange or give me my money back. He insisted that I was installing wrong or over looked something. So, after causing a big scene with the guy manager gave me my money, bought motorcraft problem solved.
94GTCoupe
1,412
92
79
CA
Dec 14, 2008
#11
  • Dec 14, 2008
  • #11
so this morning i head to 7-11 for some coffee and the paper.
drove fine the way there.
when leaving,put the car in reverse to pull out.
started moving,then the check engine light came on and the car died.
i restarted it and drove to my brothers garage where i have all my tools,on the way there,no check engine light and the car drove fine.
pulled codes,here's what came up.
157=MAF sensor circuit below minimum voltage.
158=MAF sensor circuit above maximum voltage.
next,i tested the MAF
using my meter.
tested between terminal A (red) and B (black)on MAF connector with car running at idle,at operating temp.
i got 14.53 volts.book say's there should be at least 10.5 volts,so this looks good.
tested between terminal C (brown) and D (light blue)on MAF connector with car running at idle,at operating temp.
i got .74 volts.book say's there should be approximately 0.34-1.96 volts,so this looks good aswell.
yesterday,after cleaning the TB,and IAC and MAF,i warmed the car up and ran a KOEO test and was good.
than i ran a KOER test along with a cylinder balance test,both came out fine.
any suggestion's?
GTA_V6_Mustang
1,326
Miami, FL
Dec 14, 2008
#12
  • Dec 14, 2008
  • #12
Make sure the connector for the MAF is secure and make sure that the wires are good to begin with. You may have an intermittent wire problem.
94GTCoupe
1,412
92
79
CA
Dec 14, 2008
#13
  • Dec 14, 2008
  • #13
i checked the wires and connectors.they look good.
this problem just showed up.
right now,i have the batt disconnected to clear the PCM.
i'll go for a drive in a little bit to see how it goes.
but,i will double check the wires/connectors.
thanks for the suggestion.
GTA_V6_Mustang
1,326
Miami, FL
Dec 14, 2008
#14
  • Dec 14, 2008
  • #14
do you still have the stock MAF set up in the box?
94GTCoupe
1,412
92
79
CA
Dec 14, 2008
#15
  • Dec 14, 2008
  • #15
yep.all stock under hood.
GTA_V6_Mustang
1,326
Miami, FL
Dec 14, 2008
#16
  • Dec 14, 2008
  • #16
you sure your connector to the actual MAF in the box is good? And when you removed the MAF did you remember to put the o-ring back on the MAF
94GTCoupe
1,412
92
79
CA
Dec 14, 2008
#17
  • Dec 14, 2008
  • #17
1.pretty sure
2.o-ring?never noticed an o-ring.i've removed the MAF sensor from the housing more than a few times for cleaning and never noticed it.where should it be located?
GTA_V6_Mustang
1,326
Miami, FL
Dec 14, 2008
#18
  • Dec 14, 2008
  • #18
its located on the MAF sensor. It seals the sensor to the housing.
94GTCoupe
1,412
92
79
CA
Dec 14, 2008
#19
  • Dec 14, 2008
  • #19
i'll take a look now.
94GTCoupe
1,412
92
79
CA
Dec 14, 2008
#20
  • Dec 14, 2008
  • #20
you mean here?there's nothing there.
1 of 2 Next Last
E
Alternative IACs?
  • Ethereal_Zer0
  • May 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 7, 2025
CAMTWO1070
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
