![Mad :mad: :mad:](/mustang-forums/styles/default/xenforo/smilies/mad.png)
so this morning i head to 7-11 for some coffee and the paper.
drove fine the way there.
when leaving,put the car in reverse to pull out.
started moving,then the check engine light came on and the car died.
i restarted it and drove to my brothers garage where i have all my tools,on the way there,no check engine light and the car drove fine.
pulled codes,here's what came up.
157=MAF sensor circuit below minimum voltage.
158=MAF sensor circuit above maximum voltage.
next,i tested the MAF
using my meter.
tested between terminal A (red) and B (black)on MAF connector with car running at idle,at operating temp.
i got 14.53 volts.book say's there should be at least 10.5 volts,so this looks good.
tested between terminal C (brown) and D (light blue)on MAF connector with car running at idle,at operating temp.
i got .74 volts.book say's there should be approximately 0.34-1.96 volts,so this looks good aswell.
yesterday,after cleaning the TB,and IAC and MAF,i warmed the car up and ran a KOEO test and was good.
than i ran a KOER test along with a cylinder balance test,both came out fine.
any suggestion's?
![Shrug :shrug: :shrug:](https://stangnet.com/smilies/dunno.gif)
