average water temp.
  • Thread starter Thread starter dastang2
  • Start date Start date Apr 3, 2004
First Prev 2 of 2
dastang2
2,020
tx
Apr 4, 2004
#21
  • Apr 4, 2004
  • #21
i had no shroud with this motor when it was in the truck
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Apr 4, 2004
#22
  • Apr 4, 2004
  • #22
A properly sized and fitting shroud helps air movement immensely. The fact that the truck didn't have one doesn't mean the car shouldn't have one. The cowl hood does help reduce underhood temps as it provides an easy path for underhood air passing over the radiator to escape. Because of that, it may also allow for more air to pass over the radiator at speed. Go drive the car - even revving the engine puts very little additional heat into the radiator. The engine has to work to make lots of heat - and it's not working hard at all sitting still. Let us know what happens when you drive it.
dastang2
2,020
tx
Apr 4, 2004
#23
  • Apr 4, 2004
  • #23
i do have a shroud in the car. look at the link in one of my previous posts. it shows the radiator and the shroud. the fan runs directly from the water pump. it is a stock flex fan from an 82 truck. it has a long spacer to get the fan less than 1 inch from the radiator. the shroud is from an 87 gt.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Apr 4, 2004
#24
  • Apr 4, 2004
  • #24
Yup - saw your mention of the shroud in the first post; others besides those of us engaged with this one read the threads. Didn't want anyone to get the idea that just because it worked in your truck without a shroud that it would be ok in a Stang without one. Your previous post seemed to imply that - didn't want to mislead anyone else.
First Prev 2 of 2
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
