Awww $%)&, I was stupid
Banditlead
79
CT
So, I took pictures of the carb before I took it off the car because I have a terrible memory, and I knew I would forget how all the plumbing went, and I took pictures of everything but the throttle linkage all hooked up. I think I have it properly set up now, but I am not really sure, can someone post a picture of it? Its the standard Holley 2 Barrel that came on fords, if that makes a difference.
You may commense laughing and wondering, if I can't rebuild a carb, then what the h3ll am I doing working on the car :)
It sure is fun.
Should be a ball stud that the arm snaps on. If not then a little hole the arm slides in and a cotter pin or hair pin goes in. If you took the bowl off you did put the pump arm back under the lever didnt you... :D Post pictures of what you have and I can tell you more.
