Axle Length
  • Thread starter Thread starter 89Notch
  • Start date Start date Jul 27, 2006
89Notch
1,669
MSU
Jul 27, 2006
  • Jul 27, 2006
Hello,
My dad found a turbocoupe rear end that I am going to swap in to upgrade to rear discs. The "main" brake upgrade page shows that the axles are .75" longer. I want to upgrade to a F-150 31 spline diff and get some moser 31 spline axles as well. Can I order axles that will bring the axle length back to the stock mustang length? What length are the axles? Also, what else will I need to finish the conversion? Thanks for the help.
-Jason
trbkrb
1,976
Houston, TX
Jul 27, 2006
  • Jul 27, 2006
If you read Matt's website, he does cover this. The axles and brake brackets are designed together, so you can't alter axle length and use the same stock brake brackets. If you want Fox length axles, you need to get the $160 www.northracecars.com brackets designed to use the TC brakes with Fox axles. Or if you are mechanical and can modify the stock brackets, you can cut them and mount them on the inside of the flange with some washers to move the brakes in the .75" difference. There is a thread on Corral about doing this to SN95 brackets.
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
