  • SN95 4.6L Mustang Tech
Axle or control arms?
  • Thread starter Thread starter 2002_stanGer
  • Start date Start date Apr 3, 2004
2002_stanGer
131
Phila, PA
Apr 3, 2004
  • Apr 3, 2004
Every time I brake, either lightly or hard, it creaks like old wood. I can feel it in the brake pedal too! I thought it was the axle, but the axle's in the back. I know it's coming from the front. I have ford fms c-springs on it with everything else being stock for the suspension. I rode it real hard around turns ever since I got the car back in '01. Can someone please tell me if it's the control arms? And if so, where I can get fairly good, cheap ones - don't need the best of the best.
Thnx!!
2002_stanGer
131
Phila, PA
Apr 3, 2004
  • Apr 3, 2004
bump
Roxstang
65
Pa
Apr 3, 2004
  • Apr 3, 2004
Hey a dutch boy!! The creaking you hear could be the bushings. I don't know cause I can't hear them. I suspect what you are hearing are the bushings. Grease them or replace them with polyurathan. If you can find it, use Prothan grease with the new poly's it won't eat up the bushings like regular chassis grease. As for control arms you get what you pay for so don't go cheap. I have a complete Ground Pounder coil over front suspension and K-Member and HPM Megabite Jr Lower and Megabite NON-adjustable uppers and they are a God send to my GT. IT absolutely hooks up and goes where I ponit it and really soaks up bumps in the road.
2002_stanGer
131
Phila, PA
Apr 5, 2004
  • Apr 5, 2004
Dutch boy?! I don't get it. But thnx. what do the bushings look like? Would control arms creak also?
Thnx!
2002_stanGer
131
Phila, PA
Apr 5, 2004
  • Apr 5, 2004
Am I correct in that the axle is only in the back, correct?
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
Hello from Washington State!
  • Daddys Lil Filly
  • Jun 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 10, 2026
Daddys Lil Filly
