I went to change out the differential to limited slip today and C clamps will not come out. When I push the Axles in they don't go far enough. Stopped for tonight but thought about it and looked at the other end of the axle and the ABS plate hits the ABS sensor. I unscrewed the bolt on the sensor to pull it out but it will not come out. Can these things be tapped out some towards the differential so I can push the axles in a little more?
