Axles from ranger and van
SVTFreak
106
Before someone says check, i looked in the 5 lug conversion thread.
I have the axles from the ranger and aerostar (i think) van. Where you get passenger from one and drivers from other (dont recall which). Came with the car and ive peiced together alot of the other pieces.
How much farther out will these axles push my wheels? I will be using SN95 rear disk components on them when i do the swap.
if you got the correct year and side it will be the same length as the fox axles which is why peeps do it.IIRC You will need the north racing brackets to run those calipers and a piece of pipe to put between the rotor and the axle to center them.
Ahh, old memory conjurs up memories of a bracket... Now that you mention that i think i know someone locally that has that setup.
Pipe? as in basically a spacer to push the rotor out some from the axle? Not sure i want to do that, i would ideally like to keep the same wheel position as i currently have in order to run the wheels i have in the attic hehe.
