B 303 Cam
  • Thread starter Thread starter j l smith
  • Start date Start date May 30, 2017
J
j l smith
60
west liberty ky
May 30, 2017
  • May 30, 2017
i have a 1993 mustang gt and i'm thinking about putting a b303 cam and 1.7 roller rocker with ported gt-40x heads will it run ok without tuning it.
Dan02gt
mazing how much gas smell came from that tiny hole
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
May 30, 2017
  • May 30, 2017
Yes it will run OK without a tune, but the Ford Racing alphabet cams are old as dirt. There are tons of better cams on the market.
Reactions: a91what, A5literMan and Davedacarpainter
Mstng93SSP
You have a nice rear end there Dave.
3,500
184
Mililani, Hawaii
May 30, 2017
  • May 30, 2017
A custom cam is not that much more. I still have yet to see a post titled:
"Idle surging issues with my custom ground cam!"
But I have seen plenty of:
" Idle surging issues with my (B), (E) (F), cam!"
Chris
Reactions: A5literMan and Mustang5L5
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 30, 2017
  • May 30, 2017
Reactions: a91what, A5literMan, revhead347 and 1 other person
Admin Dude
Jan 4, 1985
43,563
21,734
234
Box behind Walmart
May 30, 2017
  • May 30, 2017
Mike likes to make jokes but it was the B-cam that killed Chuck Norris.
He's ok now though.
Reactions: A5literMan and General karthief
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
May 30, 2017
  • May 30, 2017
Someone made a funny skit about the b cam years ago. Wonder if that's still around
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
May 30, 2017
  • May 30, 2017
Like previously said, there are better cams. If you are on a budget, find one used. Roller cams don't really wear out. Trick Flow Stage 1, Small Comp Cams Extreme Energy, and everyone loves the old Steeda #18 and #19 cams. There are a couple of guys on here with GT40p heads, maybe some of them will chime in with what they think is best. It's not just a matter of making power, the old letter cams from Ford are a single grind, and they have some driveability issues too.
Kurt
J
j l smith
60
west liberty ky
May 30, 2017
  • May 30, 2017
well I already have the cam heads and rockers, i'm putting a lentech valve body in it now
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
May 30, 2017
  • May 30, 2017
Yes, it probably will run ok without tuning it.
Kurt
D
Deleted member 215073
May 30, 2017
#10
  • May 30, 2017
  • #10
If you already bought the cam, and you're installing it no matter what we say, why are you asking these questions?
J
j l smith
60
west liberty ky
May 30, 2017
#11
  • May 30, 2017
  • #11
I got the cam from a friend and i'm not sure if I will use it but i'm gonna put the heads on the car in a couple of weeks i'm just not sure about the cam yet is why I was asking for info
D
May 30, 2017
#12
  • May 30, 2017
  • #12
I misread your post, I apologize.
You really should reconsider using a B cam. Like others have stated, it's outdated, and there are better ones out there. I'm doing a similar engine combo, and plan on using the Anderson Ford Motorsport N-412 cam.
J
j l smith
60
west liberty ky
May 30, 2017
#13
  • May 30, 2017
  • #13
how big is that cam and will have to tune it
D
May 31, 2017
#14
  • May 31, 2017
  • #14
From the website...
N-412 Camshaft works with stock OEM pistons with 1.6 roller rockers. RPM range 2300-6200.
302 c.i.d. This cam is to be used with 1.6 R.R. Great with GT-40, TFS or Edelbrock heads. Minimum 24lb injectors and 75mm mass air. Recommend 3.55 to 4.10 gears. Great drivability down to 1800 rpm, nice idle, rpm range 2300-6200, works best with 89-93 EEC, needs 2500-2700 converter.Example of using N-412 camshaft
DSS 306",AFM N-412 camshaft, AFR 185 heads,70 mm T.B.,30# injectors,Holley Systemax, 76 mm C&L mass air meter ,Flotech shorty headers,off road h-pipe,flowmaster 2 chamber muffler, MSD 6al & blaster coil,1.6 rr,190l itp,,BBK cold air ind,
Specs found on this site doing a quick search...
N-412 Cam Spec
Engine 302HO/351
Duration at .006 -- Int. 276 Exh. 284
Duration at .050 -- Int. 222 Exh. 230
Timing events at .050 --Int. 3/39 Exh. 51/-1
Lobe lift @ cam -- Int. .320 Exh. .320
Gross Valve Lift w/1.6 Int. 0.512 Exh. 0.512
-Lobe Seperation 112
-Degree intake Lobe to 108
-Valve Lash (hot) Int. & Exh. 0
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
May 31, 2017
#15
  • May 31, 2017
  • #15
You can run the B cam without tuning. It's outdated and won't have the best street manners or produce the most power for the combo but will work fine. If you end up with a surging idle it's from another reason. That Anderson cam is a good one and so is comp cam 264-270hr either works great imo
Reactions: mikestang63
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
May 31, 2017
#16
  • May 31, 2017
  • #16
Usually the 1.7 rockers don't cause issues. Usually get more problems from bigger valves than more lift. Test everything though, playdoh is 50 cents at Walmart.
Kurt
J
j l smith
60
west liberty ky
May 31, 2017
#17
  • May 31, 2017
  • #17
if the cars surging what would the reason be it sounds like u know about them
J
j l smith
60
west liberty ky
May 31, 2017
#18
  • May 31, 2017
  • #18
thanks guys for the info
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jun 1, 2017
#19
  • Jun 1, 2017
  • #19
Usually surging idle is from a dirty iac valve,tps sensor out of range,sometimes from another sensor,vacuum leak,or possibly a few other things I can't think of lol.
There is a sticky in tech for trouble shooting if you are having a problem.
General karthief
Mod Dude
Aug 25, 2016
28,133
10,749
213
polk county florida
Jun 1, 2017
#20
  • Jun 1, 2017
  • #20
Here it is, thanks to jrichker
http://forums.stangnet.com/showthread.php?t=698148
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
