Rebuilding another 302-
Mods:
BBK Cold Air, Off-Road Bassani X-Pipe, GT-40 Intake, 4.10's
B-Cam or a E-Cam????
Mods:
Stock cam as you really don't have major mods to require or utilize a bigger then stock cam. I would just advane or retard the stock cam to more the power band where you want it.
Either would work fine, for peice of mind check piston to valve clearance. Better safe then sorry.would either the B or the E cam work well in sync with 1.7 roller rockers???
B with 1.7's is a good combo. You get better cylinder filling with the slightly longer duration of the B cam and get some decent lift. You don't really NEED the added lift all that much with stock heads though. I forgot what stock heads flow to, but I'm pretty sure it's just about .500 and tapers off quickly from there.
