b-cam vs. e-cam
  • Thread starter Thread starter whiteyford0212
  • Start date Start date Dec 29, 2005
W
whiteyford0212
24
  • Dec 29, 2005
i have a cam ?...why is the idle on the b-cam more lopey than the e-cam but the b has less lift..is it due to the lobe sep.?..anyways i was looking at getting thumper ported heads and am deciding which cam to use..it is purely a street car btw..any help would help, haha
TrunkFunk
Banned
Dec 28, 2005
83
A1A - Beach Front Avenue ...
Dec 29, 2005
  • Dec 29, 2005
Both the B and the E have a 110* lsa.
The B has slightly less lift yes, but it has an ante more duration.
The duration is a main factor in the cams characteristics.
The valve overlap is greater which tips the scale more towards stagnant airflow at idle speeds.
Hence the lope is more stumbling than the E.
It has slightly more aggressive valve timing events.
If this street car is going to have to pass emissions I would err on the side of caution and get the E cam.
I've also heard our computers conform to the E better.
I've never used the B, but I've had an E and I liked it in a 280rwhp combo.
Yes, it's not the best cam in the world ... but it sounds healthy, has good street manners, is cheap and passes the sniffer.
Not too bad for an "alphabet cam".
SmockDoiley
1,591
San Diego, CA
Dec 29, 2005
  • Dec 29, 2005
The B-cam is designed for NA motors, and the E-cam is for power adder motors. The difference is more duration and less lift in the B-cam which makes it lumpier at idle.
RyanSG
286
Allentown, Pa
Dec 29, 2005
  • Dec 29, 2005
Yup pretty much it.
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
F
carb vs cam help needed
  • forango
  • May 2, 2024
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2025
forango
F
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
