B&M hammer shifter headaches...
  • Thread starter Thread starter Bossmanmustang91
  • Start date Start date Mar 24, 2013
First Prev 2 of 2
Bossmanmustang91
37
#21
  • Mar 30, 2013
  • #21
I just got a new shifter from American muscle didn't put it in yet
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Mar 30, 2013
#22
  • Mar 30, 2013
  • #22
mikestang63 Fuzzy dice? Are you kidding me? Lmfao
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 30, 2013
#23
  • Mar 30, 2013
  • #23
Work with me here boys. The wifey and kids got them for the car and they have my college logo and colors on them. Life is about picking your battles. lol
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 30, 2013
#24
  • Mar 30, 2013
  • #24
Great. Hope it works out for you. You'll be able to give instructions on how to install them after all is said and done..lol
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Mar 30, 2013
#25
  • Mar 30, 2013
  • #25
Just breaking balls, it's all good...
Bossmanmustang91
37
#26
  • Mar 31, 2013
  • #26
Bossmanmustang91
37
#27
  • Mar 31, 2013
  • #27
Just put new suspension n rubber on her... Finally a nice firm ride with no shakes and rattles...
Bossmanmustang91
37
#28
  • Apr 4, 2013
  • #28
I just put the new one in what a bitch.... Whole counsel had to come out. Here's my issue.... She's in park, lift up on the trigger and pull her back... I should be in reverse and i am not. I have to drop back again for reverse. Pull back again a now i am in neutral. Another pull and I am in drive or over drive. Something's not right.. Plus when I shift through the fwd gears iam not feeling it engaging when it should. Wtf???
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 4, 2013
#29
  • Apr 4, 2013
  • #29
I just put the new one in what a ****.... Whole counsel had to come out. Here's my issue.... She's in park, lift up on the trigger and pull her back... I should be in reverse and i am not. I have to drop back again for reverse. Pull back again a now i am in neutral. Another pull and I am in drive or over drive. Something's not right.. Plus when I shift through the fwd gears iam not feeling it engaging when it should. Wtf???
yeah it was a PITA having to remove the entire console and radio for a shifter install but nothing hard. Just a lot of little screws and having to maneuver it back over the B&M shifter
Wait, this is the 2nd new shifter? Definitely sounds like your cable is not adjusted properly. It took me a few times to get it right. That was the biggest PITA as it was just me having to go back in and under the car. It was a little hard shifting at first, but after a day or so it shifts nice and smooth. I lift up once to get out of P to R, then it should simply slide back once to N then again for O, D, 1. When you upshift all you do is ratchet up once through each gear and you don't need to pull up on the spoon until you get to R. You should hear it click each time you shift.
Did you put the shifter and the shift arm on the trans in neutral, loosen up the shift cable, then slide the shift cable back and forth to make sure it is not binding, then pull the slack up on the cable and retighten up the cable. Make sure the shifter will go through all the gears. I will say this- I have read complaints about the shifter being hit or miss- that the biggest complaint is there is not enough room in the cable to engage all the gears. Some people have needed to take the arm of the shifter where it attaches to the cable and put it in a vise and straighten out the bend to make it straight and give it just that little more reach. Others have fabbed up a small bracket to attach to the shift arm on the trans to extend it out an inch or so , again to give the cable some more room. If your cable is old, I would at a minimum spray it down with some WD40 as it may be binding. The B&M requires more effort than the stock shifter. It may also be stretched - another common complaint- which requires a new cable. I would have someone sit in the car while you are underneath ( car supported on jackstands of course) and have them go through the gears while you see the shift arm move. See if if moves from P to 1 freely.
Another thing could be- did you reassemble the shifter properly when you put the spoon, springs, washers, and pin in. It may not be engaging fully.
Bossmanmustang91
37
#30
  • Apr 5, 2013
  • #30
Did it all... New cable and everything. The spring, washer and spoon are all in correctly. I think I need to adjust the cable some more.
Bossmanmustang91
37
#31
  • Apr 5, 2013
  • #31
Finally got it after a million adjustments on the cable...... And of course I forget to hook up the connections behind the radio, so everything back out and back in. Now of course new problem... Iam idling at like 1800 rpms in park and neutral. When I shift into gear the rpms drop back down to where they should be. Always something with this car lol.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 5, 2013
#32
  • Apr 5, 2013
  • #32
Vacuum leak? IAC?
Bossmanmustang91
37
#33
  • Apr 24, 2013
  • #33
No it all checks out. No Vac Leaks all sensors are good I havnt had time to mess around with it but this weekend iam going to clean the IAC and i think that should do the trick. I did find that my #3 ignition wire was fried from being to close to the headers so that may be causing the comp to up the rpms.
First Prev 2 of 2
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
C
AOD wont go into park
  • chris1993
  • Mar 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2024
Silverfoxx
