[B]Which Roller Lifters to Use? [/B]
Which lifters do you use?
  • Comp Cams roller lifters
    Votes: 1 25.0%
  • Ford Racing (replacement) roller lifters
    Votes: 3 75.0%
  • Total voters
mustanghrspower
554
Las Vegas, NV
I'm getting ready to purchase a set of new roller lifters for my 306, and I would like to know if its worth it to get a set of Comp Cams roller lifters or should I just get a new set of Ford Racing stock replacement lifters. I can't find any info on the Comp ones to tell me if they are lighter or stronger, or why I should go with them. If it helps, I am using Trick Flow Track Heat heads, and a TFS stage one cam. Thanks for any suggestions!
in my opinion it boils down 2 a matter of preferance. im sure both are quality products but me personally i would go with the comp cams do to they specialize more in just valvetrain products and spend countless hours R&D'ing there products as compared 2 ford raceing products wide selection of products. im sure ford spend's time R&d'ing 2.
comp or crane or any aftermarket performance comp. generally use higher quality material in makeing there products then OEM. and are more likely 2 have a higher fatigue rateing 2 withstand higher valve spring rates needed 4 modern performance cams.
