At .050" both the B and the E cam have zero overlap. The reason the B can have more duration than the E, and they both have zero overlap at .050" is because the B has a wider LSA than the E - 112 to 110.
As for aggressiveness of the ramp, there's another important variable that's been left out of the discussion - and that's the shape of the lobe at the top or peak. Without that info, it's really impossible to determine which ramp is more aggressive, not withstanding my previous comments about advertised duration vs. .050" duration. If lifts are close (and .480 to .498 is pretty close), comparing advertised duration to .050" duration is still the best way to determine relative ramp rate. Another example - CompCam Xtreme Energy line (known for their fast ramp rates) XE270 has 270 degrees .006" and gets 218 degrees at .050" out of that. Compare to the E which needs 282 duration at .006" to get 220 at .050". Said another way - it stays open for nearly as long at .050", but it waits 6 degrees longer before it gets to .006", and it drops from .050" to .006" on closing 6 degrees sooner -- that means the ramp rate has to be quicker.
