Well I guess I can say I brought sping in just right. As some new, I took the car to the dyno so I could assure the tune was ok and everything. Before we got to business we found the car had an old school Autologic chip. Well after SGS had her strapped down and warmed up we let it rip.
1st run was 380 rwhp and 356 rwtq.
I was told the car had a 03/04 cobra fuel tank. So......I assumed it had the dual pumps etc. From what Dave seen, he said he believes its a single pump, probably focus. So it might have the cobra tank, but probably not the dual pumps. Pump maxed at 5500 for a split second then maxed at 100% at 5900 where he shut it off. Also found out the timing was locked in at 12.9*...thats right...locked in. So Idle, cruising, in boost, its always 12.9*. So there are some things that need worked on.
We did another pull to check the boost.
2nd run was 379rwhp and 355 rwtq.
At 5800-5900 when he shut it down it was around 11.5 lbs of boost. Kinda suprised it was that much because its the stock pulley with a power pipe. From the graph, power was still climbing steady at 58/5900.
I am happy with the numbers. No track duty until I get new pumps put in the car. Also going to be putting 60lbs injectors and then back for a new chip and tune
I have some vids to get up, just working out the bugs.
Getting the car loaded up:
Getting ready for a run:
Im hoping I can hold off for a little while and save some $$ and get the goodies. I get to busy in the summer so it will probably have to wait till fall
