went to GIR tonight.
first run was with the tweecer hooked up, ran a 14.3 or 4 at 98 with a 2.12 60ft. kinda pissed
2nd run ran the tweecer off and pulled the spout with 30-32* set at the dizzy. That pass the car would not even rev past 3k, bucked bad like it just would stall, cut out, rev. limit. ran a 19.9 @ 58mph.
3rd run turned off the tweecer but reset the * to 10* and put the spout back in. ran like crap again bucked, would not rev. past 3k switched ran like a 16.x
4th run took a base GT file and only changed the offset v batt. voltage, and entered a quick high and low slope based of 24 for low and 24 x 1.2 for high (or it may be reversed I can never tell off the top of my head unless I am looking at it). No timing added so 26* total. ran a 2.3 or so 60ft a 14.2 and 100mph. I gained 2mph with 6 degrees less timing and if I had gotten my 60ft to 2.0- it would have been a 13 for sure.
I wanted to make a quick last pass with 4* added global (like bumping the dizzy to 14) but they were calling 1min to last call, and the car needed to have the fan temps changed as well as it was getting hotter. So I left. I am very possitive I could have trapped at 102 or so with 4-6 more degrees. looks like I am going to datalog this very bare bones tune and see what I can put together. Looks like I may try to get to a dyno and compare the soft j4j1 tune and the new tune I got the better results with.
Still not were I want it to be even with the added 4-6 but I also need to redo my valve train and I think that is prob. the rest of my prob.
