Backfire?
Just got the old stang back on the road recently. I lost oil pressure so I yanked the engine out to investigate. Turns out one of the oil galley plugs that the machine shop installed, worked its way out. Well, got 'er all back together and I've been driving it for about 2 weeks (not my daily driver). Since the rebuild, and nothing really changed except for the addition of an electric fan, I am getting a lot of backfiring. It happens in neutral when I give the throttle a good rip. It also happens sometime when I shift gears while driving. RPMs are usually up above 3000. Is this a rich or lean condition?
Backfiring out the intake is either a valve stuck open or a lean mixture or spark plug wire(s) connected to the wrong cylinder(s). Check compression on all cylinders and then look for vacuum hoses loose, cracked, misconnected. Check the line for the vapor recirculation system – it is easy to knock loose and not see it when you connect the air pump plumbing. If the vacuum line for the EGR valve and the air pump are cross connected, some very strange things can happen. Check the mass air flow electrical connection and see that it is tight, the same goes for the fuel injection wiring harness connectors up on top of the manifold near the firewall.
Lean fuel mixture breaks out into several sub categories:
A.). Vacuum leaks
B.) Air entering the intake without passing through the MAF
C.) Failure of the MAF, BAP/MAP (Baro or Manifold Air Pressure, same sensor, different name), ACT (air charge temp), or ECT (engine coolant temp). These should set a code in the computer.
D.) Leaking exhaust gases from EGR valve at WOT.
E.) Clogged fuel injectors.
F.)Fuel injector wiring problems causing injector not to deliver rated flow.
G.) Computer problems: (computer problems are not common like sensor problems)
H.). ROM has bad data in fuel or timing table. This should also set a code in the computer.
I.) Failure of one or more of the computer's driver transistors for the fuel injectors. No code set on this one.
J.) EGR not opening at cruse power. The computer adds timing advance to compensate for the slower burning speed of the EGR diluted intake charge.
K.) MAF calibration off or mismatched to injectors.
I agree with jrichker's post for popping in the intake. Is it backfiring out of the exhaust? It maybe a stupid question as you'd probably hear it, but do you have an exhaust leak down stream of the headers? That can cause a backfire from the tailpipes as the additional air flowing in (sucked in) through the leak can give the exhaust (unburnt fuel) the last thing it needs to ignite.
- Jeff
