  • 1994 - 1995 Specific Tech
Backfires.. how to adjust timing ?
  • Thread starter Thread starter TheDamned
  • Start date Start date Apr 7, 2006
TheDamned
"I am Canadian and Damned for it!"
Jul 22, 2003
457
Montréal, Québec, Canada
Apr 7, 2006
  • Apr 7, 2006
http://www.doozed.com/95GTRoar.mpg
You can hear I have mad backfires in the video... Somebody told me it ****s up the engine.. I never touched the timing, all stock settings unless the guy before me changed it.
How the hell do I change it so it doesnt backfire anymore?
Thanks.
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Apr 7, 2006
  • Apr 7, 2006
I dont think the timing is the problem. Just the fairly cold weather and off-road H-Pipe. I say its normal. If you want to touch the timing , well at least bump it to have more power.
TheDamned
Jul 22, 2003
457
Apr 7, 2006
  • Apr 7, 2006
Well it do that even in our "warm" Québec summer like in August
TheDamned
Jul 22, 2003
457
Apr 7, 2006
  • Apr 7, 2006
Any other inputs ?
95GTV8
386
Washington State
Apr 7, 2006
  • Apr 7, 2006
i have the same question. I have an o/r h w/ stock C/B. I don't think it's so much of backfiring as just popping during deceleration. People tell me this is due to the absence of cats and unburnt fuel is popping in the pipes. However i've heard plenty of mustangs w/ o/r pipes that don't do this. Does this have something to do w/ stock catback? Exhaust leak maybe?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 7, 2006
  • Apr 7, 2006
that's not backfiring....backfiring sounds like a gunshot..
It's normal, don't worry about it.
Scott
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 7, 2006
  • Apr 7, 2006
Some decell pop and some don't due the differences in combos causing some to have a/f ratios too fat at the moment of decell.
Grady
95GTV8
386
Washington State
Apr 7, 2006
  • Apr 7, 2006
hrmm, any way to nix the decel popping? It gets kind of old. I have a fairly mild combo, if you could even call it one. I'm hoping to get cylinder heads this summer.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 8, 2006
  • Apr 8, 2006
I've had it ever now and then depending upon what parts were used at the time.
I've found the GT is more prone to do it than the Cobra due to how the pcm is setup.
There are fuel shut off adjustments and the like that can be adjusted if you get inside the pcm.
I don't know how you could dial back the fuel to try and kill it without possibly hurting yourself in other areas of the tune with mechanical means
I myself don't care for it but I've seen others who say they like how it sounds.
Grady
TheDamned
Jul 22, 2003
457
Apr 8, 2006
#10
  • Apr 8, 2006
  • #10
Grady
I like the sound aswell, but some guy told me backfires like in the video is killing my engine, that it doesnt like it... Is it true ?
bimmertech
1,123
merriam, ks
Apr 8, 2006
#11
  • Apr 8, 2006
  • #11
not true.
it may also be leaks in the exhaust after the muffler that will suck in air and make a popping noise.
is your exhaust welded or did you just use clamps that came with the kit?
if it is clamped, get someone to weld it up and most of that will go away.
TheDamned
Jul 22, 2003
457
Apr 8, 2006
#12
  • Apr 8, 2006
  • #12
bimmertech said:
not true.
Not sure I didn't installed it but i know they repalace alot of parts because of rusts so i'm pretty sure it's weld up... But I may have some exhaust leaks in the mufflers, i'll have to check it out.
I like the sound of the backfires anyway, it sounds badass... Some guys told me it was dangerous for the engine that's why I asked... I'm glad it's not.
Any other inputs ?
TheDamned
Jul 22, 2003
457
Apr 9, 2006
#13
  • Apr 9, 2006
  • #13
TTT!
GRGT1994
1,034
#14
  • Apr 9, 2006
  • #14
Like said above, that is NOT backfire. That is exhaust pop. I have heard some Corvettes with only mild exhaust mods do the exact same thing.
If you like that sound, the don't worry about it.
D
How to adjust 1994 Covertible--passenger side doesn't mate up right.
  • DPP
  • May 23, 2025
1994 - 1995 Specific Tech Jul 12, 2025
DPP
D
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
