Backfiring after MSD 6AL install...
  • Thread starter Thread starter BlackFox5.0
  • Start date Start date Feb 12, 2004
BlackFox5.0
3,514
Massachusetts
Feb 12, 2004
  • Feb 12, 2004
I noticed that my car seems to pop more under deceleraion, esp in the upper RPMs, is this normal? Or is something wrong? I have my autolite plugs gapped to the specs of a stock engine, and still have the stock coil.
willys1
1,004
New Jersey
Feb 12, 2004
  • Feb 12, 2004
Did you double check the plug wires,,,rite fireing order? Its a simple mistake to make.
W
wildstang347
83
  • Feb 12, 2004
ive noticed something similar with mine, although my digital ignition is not the MSD version but the experience was the same.
the amount of initial timeing my motor ran best with was less then before the installation of digital ignition, requireing my particular applications ignition curve 2 be slowed down 3 degrees on the dyno netting a few more horses gained and the elimination of problem.
also your stock coil may not be able 2 keep up with the MSD either.
BlackFox5.0
3,514
Massachusetts
Feb 12, 2004
  • Feb 12, 2004
I never took the plug wires off, and if I did, they are numbered
W
wildstang347
83
  • Feb 12, 2004
how old are the plug wires? after you mentioned they were numbered it made me think you are still running older wires with the new ign. setup.
if they are old you may wanna test them checking there resistance with an ohm meter and replace if reading is high.
BlackFox5.0
3,514
Massachusetts
Feb 13, 2004
  • Feb 13, 2004
They are FMS wires, maybe 2-3 years old?
88GTStreetRod
376
USA
Feb 13, 2004
  • Feb 13, 2004
My car does the same thing with the MSD. Everything is installed correctly
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical MSD Blaster TFI Coil 8227 loud Chirping Noise.
  • PonyGTrider
  • May 25, 2025
Fox 5.0 Mustang Tech May 31, 2025
PonyGTrider
  • dan50
  • Jul 18, 2026
dan50
