  • 1994 - 1995 Specific Tech
Backfiring is this normal?
  • Thread starter Thread starter 91LX_5L
  • Start date Start date Jun 10, 2005
91LX_5L
1,943
British Columbia
Jun 10, 2005
  • Jun 10, 2005
My car backfires if I tap on the gas (just like 1/8th throttle) like 3-4 times in a row, It did this in 3rd at about 2,000rpm. What could that be?
WhiteStallionGT
465
Northern VA / VT
Jun 11, 2005
  • Jun 11, 2005
Check out my thread, the same thing happens to me, no one has responded yet.
dstanggt50
1,316
Woodinville, WA
Jun 11, 2005
  • Jun 11, 2005
Have you check timing and codes??, those would be the first things I would check, maybe vacuum leaks, clean maf, the usual.
18mustangs
533
Virginia Beach, VA
Jun 11, 2005
  • Jun 11, 2005
Also check the O2 sensors, my car did the same thing, I switched to LT headers so I replaced the O2 sensors and the problem went away. Run the codes first like dstanggt50 said.
Tim
donjohn
1,757
Irvine - Southern California
Jun 11, 2005
  • Jun 11, 2005
i've heard it's an o2 censor problem, but mine only does it once in a while when i rev hard
91LX_5L
1,943
British Columbia
Jun 11, 2005
  • Jun 11, 2005
humm mabye my o2 sensors are messed that might be why I have a power loss problem!?
Timing is at 16* I was going to bump it back down to 14* soon.
I allready cleaned maf, set tps, cleaned iac.
yellowstang1994
338
  • Jun 11, 2005
Do you have any exhaust leaks? I stripped one of my header bolts so I left the nut off it. It's on there pretty good while i'm ordering a new bolt kit but once in a while my car will backfire on load and sometimes with no load because of the leak (which you can't even hear but it's there). I'd check for leaks too!
91LX_5L
1,943
British Columbia
Jun 11, 2005
  • Jun 11, 2005
I got a header leak, gasket is blown...
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
Differential noise over bumps
  • sharkrat
  • Apr 10, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 18, 2026
TPony
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
