  • SN95 4.6L Mustang Tech
BAD backfire HELP!!!
  • Thread starter Thread starter delldoe
  • Start date Start date Feb 3, 2008
D
delldoe
  • Feb 3, 2008
So hears the deal, pulled out onto the highway and smashed it 1st through 3rd and right as I let the clutch out into 3rd my car started backfiring real loud. "sounded like a shotgun going off" turned the car off and coasted off the road. Now it won't even start and is backfiring through the intake exhaust. got a po340 code which is for the camshaft position sensor. Put in a new one, still won't run. changed out the crankshaft position sensor and have same results. Has anyone had this happen to them??? let me know what you think
M
MichaelsLilGray
32
Tyler, Texas
Feb 3, 2008
  • Feb 3, 2008
I have no idea man.. but if you figure it out... please share with us.. Cause that is the strangest thing ive ever heard. good luck on it
RandyStinchcomb
1,159
Randallstown, Md
Feb 4, 2008
  • Feb 4, 2008
what year is the car? if it's a 2002 up, it is an alternator problem and try and buy oem Ford and NOT some parts store crap wth the "lifetime warranty" type sales pitch
pretty common issue too, do a search on this and you'll sea.....
twogts4us
4,188
12
79
Dunedin, FL
Feb 4, 2008
  • Feb 4, 2008
I didn't experience the way you got to your problem, but I had one of the many 2002 alternators that died an early death...fortunately got it replaced under warranty. They also swapped out my battery for free...
blown4_6
35
PA
Feb 6, 2008
  • Feb 6, 2008
I think I might have had the same kind of problem. The code kept coming up and said crankshaft position sensor. I was pulling my hair out trying to fing out what it was and it ended up being the wiring on the CSPS ( the connector to be exact ) was the slightest bit loose and woulld make good contact sometimes and sometimes not, but while I was serching for this problem I talked to quite a few mechanics and bad coils could also cause this or (1 bad coil, 2 bad, 3 bad ect.) I could only get the car to rev to about 5300 rpm then it would backfire between 5300 and 5900, never got it to go past 5900 ( professionaly built motor to rev to 7400 rpm ) and my boost was all f'd up on the street when under a load. I would mash the gas and it would sputter, backfire and a couple times even shut off, but it would always restart easy. Havent had it tuned again since weather is bad now but we had 1 nice day and I took it out fora ride after fixing the connector and it ran great with full boost and no hesitation at all. But it took me about a month or so to track it down I tried all diffrent things. but just remember if it isnt the connector it CAN be a bad coil or so. I did tons of reserch on this. Hope this helps. Here is a vid of my car on dyno backfiring at about 5900rpm
http://www.youtube.com/watch?v=Ol3v0eDIH7E
joshheat25
871
Delaware
Feb 6, 2008
  • Feb 6, 2008
yea I had the same thing happen to me and it was the Alternator. bought a new one and the prob went away!
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
L
Drivetrain 2000 GT High Idle - Pulling Out Hair - Help
  • lleonard1185
  • Jan 18, 2025
SN95 4.6L Mustang Tech Jun 4, 2025
Leo090
L
